Hi Team,
discharge function is base on the Enable pin, reght? nothing to do with UVLO?
left picture i think is correct, but the picture on right is correct? because we found that there was a step by step drop.
1. If application circuit remove feed-forward cap.(22pF) , can it still work? or affect converter stability?
2. If application circuit PG pin tie to GND , can i do this?
3. can we let TLV62585 pin 6 tie to output ? can it still work?
