we have used TPS22969 load switch for one of our design , this design requires a specific power on sequence, while probing the output of the load switch we found that the there Is 1.8V present at the output pin even when the enable voltage is 0. this creates a unwanted step in the power sequence in the CPU.
As long as the enable is in 0V the output remains at 1.8V , when the enable is provided the switch conducts to 3.3V volts.
Please let us know how to solve the issue.
