Hi all,
I could not find technical difference of LED linear driver, backlight driver, and Indicator.
Could you please explain detail about the difference?
Thank you
Hi all,
Thank you
Hi gary,
Linear LED driver works unde lile LDO mode, there is no switch MOS inside or external;
Backlight driver usually wroks under bost mode and need god dimming performance which is uesed for LCD panel;
Indication usually has multi channel and usually each channels output low current.
You cna search on TI.com and check the difference.
BR
Sean
Hi Sean,
Thank you for your answer.
I could find that the current of backlight driver is 100mA to 150mA, and Indicator driver is under 70mA.
I know that backlight driver is usually used on the cluster application in automotive, can Indication be used also on the cluster?
Where application the indication driver is used?
Thank you
