Other Parts Discussed in Thread: TPS23881, TPS23731, TPS23734
Dear team,
I would like to double confirm with you about input UVLO spec of TPS23730.
According to IEEE802.3af spec, VDD input range is from 37V to 57V at PD side when negotiation successful.
In TPS23730 datasheet - *PD input supply UVLO_rising*, the voltage range is from 35.8~39.5V which may lower than .af input spec.
Could you double confirm if TPS23730 can support IEEE802.3af PSE or not? Thanks.
BR,
Ben
