Hi Team,
A customer is asking for the minimum input current of TPS2561A relative to the output current.
Danilo
Hi Team,
Danilo
Hi Danilo,
I am not clear with your question.
But input current is same with output current.
For TI's policy, I will first click resolved button.
If you have any other concern, contact me any time.
If you think resolved, please help click 'Issue is solved button'.
Thanks.
Hi Ziv,
The TPS2561A is a dual power switch with 2 Fault outputs and 2 EN inputs. I understand that the EN current and supply current are in micro ampere range. For this reason, we can consider that the input current is the same as the output current since the losses are negligible. I think this answers the customer's inquiry.
Thank you for your support.
Danilo
