Dear Sir,
While I'm testing TPS61023 to check the current rating the IC got internal damage between the SW and GND pin. It shows Short-circuit. After replacing Ic again I checked again the same problem occur after some time. I used the circuit which is recommended in the datasheet. I also used the same resistor, capacitor and inductor values?. please help to fix this problem
Mani
