Other Parts Discussed in Thread: BQ40Z80, GPCCHEM
Hi~
1. We use 7 strings of LTO batteries to make BMS. Can we set soh in bq40z80?
2. If yes, where should I start?
Adam
Hi~
Adam
Hello Adam,
Yes, the BQ40Z80 supports SoH.
You can start with the Technical Reference Manual(Section 7.7) to learn more about SoH in the BQ40Z80.
Luis Hernandez Salomon
Luis H. S. said:Hello Adam,
Best Regards,Luis Hernandez Salomon
Hi~
Thank you for such a quick reply.
Are my current steps as follows?
1. First create the chemical ID and settings.
2. The first step to operate these, should GAUGE_EN=1 be set first?
3. Let the battery charge and discharge learning.
Also, is there a formula for soh calculation in BQ40Z80? Can you describe it?
Yes. If your cell is not found in the Chemistry Table, use the GPCCHEM tool to find a closely matching chemID. Using the GPCCHEM tool ensures that the learning cycle will not fail.
Yes.
I would suggest you checking the guide How to Complete a Successful Learning Cycle for more information about the learning cycle using the BQ40Z80.
4. Also, is there a formula for soh calculation in BQ40Z80? Can you describe it?
I don't believe there is an exact formula. A simple formula would be Full Charge Capacity/Design Capacity. However, the SoH in the BQ40Z80 is calculated by simulating the Full Charge Capacity using the typical current of the application. You can read once again Section 7.7 of the Technical Reference Manual for information regarding SoH.
Hello Luis~
First of all, I wish you a happy weekend~
Thank you very much for your assistance, these are very useful information.
But in the cycle of battery charging and discharging, battery balancing has not started.
Attached here is the log of my test. Could you please help confirm that there is a problem with the settings in that part?
Adam06180817.rar
