Other Parts Discussed in Thread: TPS548D22
Hi Team,
The datasheet shows "outer diameter of 20 mil" as the following.
I believe it is typo because it is too difficult to put 35 thermal vias for TPS548D22.
Could you look into it?
Yaita
Hi Team,
Yaita
The 0.2mm (approximately 8mil) in the Land Pattern Example is the platted hole "inner diameter" of the vias.
The Layout guide line is talking about the outer diameter of the annular ring around the via. A 5 x 7 array of vias spaced 20mil (0.5mm) center to center will fill a 3mm x 4mm area within the thermal pad.
