Using this part in a battery powered application.
Does this part provide reverse wiring protection (battery installed backwards) ? Or would a diode (as a example) still be required on the output to prevent the circuits/IC's from potentially being damaged?
When EN is disabled, the part enters shutdown mode. Is Vin just pathed thru to Vout in this case?
