Other Parts Discussed in Thread: TPS65381A-Q1, TMS320F28069M
Hi team,
Do we have a reference design that using TPS65313 to power the C2000 DSP?
Hi team,
I will check with TPS65313-Q1 applications owner.
In parallel, we do have TPS65381A-Q1 powering C2000 app note: https://www.ti.com/lit/an/slva528c/slva528c.pdf
Do you have design criteria that make the TPS65313-Q1 a better fit?
As Kevin pointed out, for C2000, we recommend TPS65381A-Q1 device. If you have special reasons why this cannot be used, then TPS65313-Q1 can be explored. But we don't have any reference design document for C2000 with TPS65313-Q1 PMIC.
Murthy
We have a Resolver-Based Motor Control Reference Design which uses C2000™ TMS320F28069M MCU and TPS65381A-Q1. Below is the link to the reference design:
https://www.ti.com/tool/TIDA-01507
Ivan
