I have a design scenario where my ThetaJ will run at 126degC. I would like to reduce this and would like to know if it is possible to load share with this device by using two in parallel? If there is a method for load sharing what is the correct way to use two of them? Is there any special connection or consideration between the two?
Thank you,
HSG
