TPS25942L: Floating pins
Part Number: TPS25942L
Hi team,
To reduce BOM cost and power reduction my customer would like to leave pins FLT, PGOOD and IMON floating on the TPS25942L..
Is this ok?
Obinna.
  • HI Obinna,
    Yes, you can leave the FLT, PGOOD and IMON floating on the TPS25942L.
    FLT and PGOOD are just open drain pins. Leaving them floating shouldn't  cause any issue.
    IMON pin can also be left floating if you do not need the load current information.
