Other Parts Discussed in Thread: TPS92641
Is there a similar LED driver with an extra output for driving a low side mosfet to replace the "lossy" schottky diode?
I haven't done any prototyping just yet with TPS92518 dev. boards, but just as a concept adding a half-bridge driver (i.e. IRS2007STRPBF, random functionally equivalent IC) and a mosfet to replace the recirculation diode. This will throw off set current values by somewhat (due to added propagation delays), but could be (?) calibrated out. Also dead time between switching would be needed to avoid shoot-thru.
This can be useful for battery powered lights, when i.e. a RGBW LED I@2.5A (each) and a diode Vf@0.35V, (not considering duty cycle derating, assume Vin >> Vled) we get ~0.8W. With 4 LED in RGBW this would be a considerable ~3-3.5W.
Shunt dimming must also be part of this design('s considerations).
Martin
