Part Number: TPS2001C
Hi team,
May I have your explain for Reverse Current Blocking more detail of the TPS2001C?
We saw the datasheet mentioned Reverse Blocking but not seeing any detail and not seeing in block diagram.
Thank you!
Hi Zoe,
The internal circuit is back to back MosFET.
As disabled, the power switch will block the reverse current due to the back to back parasitic body diode.
For TI's policy, I will first click resolved button.
If you have any other concern, contact me any time.
If you think resolved, please help click 'Issue is solved button'.
Thanks.
