TPS62148: GND solid pattern under inductor
Part Number: TPS62148
Hello experts,
I got question about GND solid pattern under inductor from customer. Could you give me advice?
In generally, it is better to remove GND solid pattern under inductor because it may cause noise influence (e.g. eddy current?)
But, from the view of thermal performance, it is better to prepare GND solid pattern under inductor, I think.
If we use 4 layer PCB for TPS62148 design, could you give me comment which is better?
1) Remove GND solid pattern on L1, prepare GND solid pattern on L2/3/4
2) Remove GND solid pattern on L1/2/3, prepare GND solid pattern on L4 only
Also, if you know good app note or tech document, could you tell me?
I would appreciate if you would give me comment.
Thanks and best regards,
Ryo Akashi
