Other Parts Discussed in Thread: TPS65381A-Q1
Might I request the Pin FMEA for part: TPS65023-Q1
Thank you,
Iain
Thank you,
Iain
This question has been assigned to the Applications Engineer supporting the device.
You should get an update soon.
Ivan
Iain,
Sorry, but I am not aware of a pin FMEA for the TPS65023-Q1 device. The Electrical Characteristics are guaranteed across a wider temperature range in addition to some other AEC-Q100 qualification listed in the datasheet.
AEC-Q100 Qualified With the Following Results: –
Parts that have pin FMEA documentation typically have it listed in a section that requires myTI login called my SecureSoftware which is restricted to users who request access and get approved.
For example, the TPS65381A-Q1 has a section in the product folder underneath the Product Details that says:
Functional Safety Documentation is available. Request now
Parts that have this "More Information" special note typically have pin FMEA and other documentation available that is specific to Automotive designs.
