TPS54228: SGND PGND
Part Number: TPS54228
In TI datasheet talked about SGND and PGND but in them layout it’s seems that it’s not implemented:
in my layout i think that need to separate the SGND and PGND like the red line, please advise:
  • i think it's better like:
  • Hi Shay,
    The proposed layout you have included here will likely work fine, but we would recommend for the best results to use the layout detailed in the datasheet. As a side note, the datasheet layout does respect the rules regarding SGND and PGND. What is labeled as the Analog Ground Trace is the SGND. The lower feedback resistor connects to the SGND and the SGND connects to the PGND  in one location.
    Kyle Patrick
