BQ51050B: Functionality of EN2 pin
Part Number: BQ51050B
Hi
I am bit confused about functionality of EN2 pin. From datasheet i understand like, this pin is for setting the priority and if this pin is low then USB wired charging will be preferred. Means if low is there on EN2 , if only wireless charging input is there it will charge from that but once the USB power is plugged in then external battery charger will charge the battery.
Please clarify this.
