Other Parts Discussed in Thread: UC2845
hi,
looking for a dc-dc flyback buck converter with
Vin=80vdc
Vout=12vdc
Iout=10A max
please suggest a low cost solution
regards,
Kalisankar.V
hi,
Vin=80vdc
Vout=12vdc
Iout=10A max
regards,
Kalisankar.V
Hello Kalisankar.V,
You can use WEBENCH to create a design suitable for your requirements
WEBENCH is located here:
https://webench.ti.com/power-designer/switching-regulator
A non isolated buck will be more efficient and lower cost than a flyback
But if isolation is a requirement then you will need to choose a flyback
You can pick a design using the UC2845 family of parts from the results obtained when you run WEBENCH.
John
Hi John,
thanks for your valuable reply. i have checked the part which you suggested. In this design can you give more detail about the transformer?
Hello Hello Kalisankar.V,
Webench will output the transformer parameters required to design a transformer.
You can send this information to your local supplier and ask them for a sample.
John
