Other Parts Discussed in Thread: TPS63001
TPS63001DRCR
Use The recommended circuit,Power supply 3.6 v, limit current 0.5 a, when the load instantaneous start circuit is greater than 0.5 a, switch power recommendation circuit inductor L1 continued 0.5 a discharge, and the power supply voltage low,I want to know what's causing it, how the circuits should be changed
