TPS62821: Without pull-up or pull-down on EN pin can damage IC ?
Part Number: TPS62821
On my design the enable pin of the buck converter TPS62821 is controlled by a µC, but before the µC is programmed the EN pin is leave floated and VIN is powered.
During this time, the output of the buck converter is probably enable or not, but there is a possibility to dammage the component, and it is no longer functional ?
Best Regard's,
