TPS1HA08-Q1: Unused pin recommendation : Float or GND with pull-down
Part Number: TPS1HA08-Q1
I want to ask one topic.
 According to datasheet P.5, we can find the description "Float or ground through Rprot resistor" on "Connection if not used" column. Which do you recommend "Float" or "GND with pull-down"?? Also, please let us know the reason to select.
He is thinking "Float", however he wants to know the merit/demerit.
Thanks and best regards,
M.HATTORI.
