Other Parts Discussed in Thread: GPCCHEM, BQSTUDIO
Hi,Sir:
We had get a strange issue that the FCC read is 0mAH,
the RM capacitor is 0mAH also.,
we try to charge the battery,the voltage is increase,
the AI also had a value.
the smooth we disable.
the cycle count is about 100cycles.
the battery hadn't had the issue before.
need your kindly help to advice how cause the issue happen?
eg, which register or which part will cause it?
Thanks!
