Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
BQ77908A: Current flows
Part Number: BQ77908A
Question from customer as below.
 I am using the bq77908A in a 7 series circuit, but the actual measured value of the input current was as follows.
What is the current flow in the internal circuit of the bq77908A?
 The bq296xxx series has the following internal circuit configuration.
  Referring to another company's 2nd protection IC, the internal circuit of the multiplexer block is as follows, so I think that the currents above and below Vx Pin cancel each other out and the Typ value is zero. ..
Kagawa
