Other Parts Discussed in Thread: EV2400, , BQ34Z100
Hi, I'm modifying the parameters of
design energy and desig capacity for a 12 volt 6 amp lead battery when changing registers values are beyond maximum vales defined for parameter and the new indicated values are not saved in the flash
design energy 72000
desig capacity 6000
or how the procedure should be to make changes to these values or what configuration registers are required.
Thank you for your attention
