TPS62480EVM-671: Output current is not Exceeding 3.7A at 3.3V Output even if we change Load Resistor
Part Number: TPS62480EVM-671
We are working on TPS62480EVM-671 module. We changed the FB resistors to 540K & 120K for VOUT=3.3V and VIN is 5V. We set the VSEL=LOW, MODE=LOW and RS pin Shorted to ground. We have connected 0.6ohm load resistor to check the Iout=5.5A. But the Output current is never changing beyond 3.7A.
Please let us know your thoughts on this.
