Dear TI Team
I would like to ask about operation of BQ27425-G2A.
We have confirmed in the data sheet that the battery level is predicted by the following method.
"The bq27425 device measures charging and discharging of the battery by monitoring the voltage across a small value integrated sense resistor (10 m Ω, typical) located between the system VSS and the battery’s PACK– terminal."
For the remaining charge after battery replacement or system reset, is the voltage measured in the same way as above to predict the remaining battery charge?
Y.Ottey
