TPS53513: TPS53513, Enable pin assert sequence.
Part Number: TPS53513
 In page #16 of data sheet, Figure 33 shows that enable pin should be asserted after VDD is stable.
Is this a requirement to make TPS53512 works? I am using a resistor divider on enable pin from other power regulator,
The enable pin may go to high before VDD is stable.
Tony
