Other Parts Discussed in Thread: TPS25942A,
I am learning the eFUSE.
And could you share the difference between TPS25940A and TPS25942A.
Thanks.
Hi Jiaxin,
The difference between TPS25940A and TPS25942A is on Pin no. 1 .
Pin 1 on TPS25940A is DevSleep Mode control. A high at this pin will activate the DevSleep mode(Low Power Mode).
Pin 1 on TPS25942A is Diode Mode control pin. A high at this pin activates the non-ideal diode mode.
Hi Praveen,
Thanks for your reply!
And my problem has been solved.
Thanks again.
