In the spec, there are 3 conditions of operation: 1) Master, 2) Internal Oscillator and 3) External Synchronization. I intend to use the option 3, External Sync.
I have 3 questions:
1) I want to know what happens during start up, should the SYNC pin be held Low, High, or Open?
2) What happens if the SYNC pin is grounded or held high?
3) From another similar issue on the forum if you lose the SYNC signal, the PWM will adopt the frequency set by the RT resistor. It will not go to 500KHz, correct?
