Part Number: BQ25606
HI
How to control charging and discharging current in Supplement Mode period?
Thank you so much
When the system voltage falls 180 mV (VBAT > VSYSMin) or 45 mV (VBAT < VSYSMin) below the battery voltage, the BATFET turns on and the device enters supplement mode.
A new charge cycle starts when the following conditions are valid: • Converter starts • Battery charging is enabled (CE is low) • No thermistor fault on TS • No safety timer fault.
Ning.
