We are using the TPS54020 regulator which was originally designed for 5V output. However due to connector voltage drops we need to raise it to 5.1V. The website and webbench say Vout can range 0.6 to 5V however the data sheet gives no value for Vout max.
Can you please let me know what is the actual Vout max and the tolerance on this.
We have adjusted the feedback resistors and it is fine at 5.1V however not happy to run the device outside specification long term so may need to be designed out and replaced
