My customer plan to use TPS2546 for BT speaker. There have 2 questions need your help.
TPS2546 need to operating in DCP mode and support load detection function.
1. If charging external device, STATUS pin need to output high.
2. If no external device be connected, STATUS pin need to output low.
Questions :
Q1. Could you provide a guide about how to setting CTL1, CTL2, CTL3, ILIM_SEL port ?
Q2. If not using DP_OUT pin and DM_OUT pin, how to connect them ? Is it need to floating or pull down/high ?
