TPS2001D: Difference from TPS2001C
Part Number: TPS2001D
Other Parts Discussed in Thread: TPS2001C,
Hi support team,
What is the difference between TPS2001D and TPS2001C?
Is there anything other than the following?
  TPS2001D is lower cost than TPS2001C.
  TPS2001D does not have a package equipped with Power PAD.
I would like to know the precautions when replacing TPS2001C with TPS2001D for cost reduction.
Dice-K
  • Hi Dice-K,
    Correct with these two points you point out.
    Both device with very similar performance.
    C/D version with different bonding wire craft.
    D version may be with shorter life expectancy than C version.
    But I think that makes no much difference and can be replaced.
    For TI's policy, I will first click resolved button.
    If you have any other concern, contact me any time.
    If you think resolved, please help click 'Issue is solved button'.
    Thanks.
