Part Number: LMZM33606
Hi,team
In the Datasheet of LMZM33606RLX, MSL Peak Temp is 240C(Level-3-240C-168 HR). and there is a note :The moisture sensitivity level rating according to the JEDEC industory standard classifications, and peak solder temperature.
However, JEDEC standard shows peak temperature is 245C while datasheet is 240C.
My customer thinks the datasheet should be revised. please advise,thank you.
