BQ25790: VREG setting in REG01 register
Part Number: BQ25790
Can we use BQ25790 to support a so called "smart battery" which may need to request different charging voltage to battery based on different environment (e.g. temperature)?
From BQ25790, it seems we can only use VREG to control the voltage level which decide when the charging mode switch from CC to CV mode.  if this is true, we can't configure the battery charging voltage dynamically as requested by battery, right?
THanks!
Antony
