Hi ,
1. could you help me to get the failure rate of TPS43351-Q1?
2. hot to calculate its fit?what is the standard?
3. how many transistors are included in the Power IC?
thanks !
Hi ,
thanks !
All reliability information is availability on ti.com at this link:
https://www.ti.com/support-quality/reliability/reliability-home.html
You can find the FIT Rate estimate here, searching for the orderable part number of the device (TPS43351QDAPRQ1):
https://www.ti.com/quality/docs/estimator.tsp
An explanation of FIT rates and acceptability can be found here:
https://www.ti.com/support-quality/reliability/calculators.html
As far as I know, TI does not publish the number of transistors in each device. If we do, you would be able to find it on the Quality & Reliability page along with all the other information you requested.
