I am planning to use a Smart High Side Switch like the TPS1HB16-Q1 (https://www.ti.com/product/TPS1HB16-Q1) in a product to drive and protect different loads as seen in the figure below.
I know it is AEC-Q100 qualified for Short Circuit Reliability but does that mean I can use it as a fuse replacement using the adjustable current limit? I read in different application notes that it enables you to use smaller cables, connectors and PCB traces and the figure below doesn't show additional fuses but it is never explicitly mentioned.
Thanks for your help!
