Other Parts Discussed in Thread: BQ77PL900, BQ76942
BQ77915
Can you please suggest simmilar standalone IC for 6 Cell?
Hi Murthy,
The BQ77915 would support 6 cells with 2 devices stacked, it does require the second IC for the 6th cell. The devices are factory configured.
The BQ77PL900 can support 6 cells operate standalone and support 6 cells, it is an older part and has rather limited configuration.
The BQ76942 is presently sampling and can support 6 cells and operate standalone, the production device will have balancing if that feature is desired. It is highly configurable.
Both the BQ77PL900 and BQ76942 have high side switching and have monitor features.
Hi Murthy,
We hope our evaluation board user guides, application notes, videos and other references will help you design with our components as needed for your system. If you would like me to look at a schematic you should be able to hover over my name to select an option to send a message. I have sent you a message in that manner.
