My customer would like to use the trim of output voltage with VREF_TRIM setting.
Please let me know how to set and effect the VREF_TRIM.
For example: make offset as -46mV. VREF_TRIM value should be -23
In this case, what is value in hex/bin set to VREF_TRIM?
Below programming procedure is correct?
1. write trim value into VREF_TRIM
2. write 0x17 to VOUT_MODE
Katsu
