Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS61088-Q1: Iswitch limitation
Part Number: TPS61088-Q1
Other Parts Discussed in Thread: TPS61378-Q1
Customer is evaluating TPS61088-Q1 vs TPS61378QWRTERQ1 for a Automotive TCU application.
TPS61088-Q1 seems to be a better fit as it has higher switch current, I can also use Webench, while not yet with the TPS61378-Q1 being it a new one.
I see in the document in NDASALES/ "TPS61378/79-Q1 Spielberg Automotive Low VIN Post-Boost for PoC, A2B for Audio Amp, CAN supply"
that the Iswitch of the TPS61088-Q1 is limited to 7A in the automotive version, can you please confirm? I did not find this limitation also reported on the ds of TPS61088-Q1.
Please email also in private if needed.
a-faggio
Many Thanks,
Antonio
