BQ20Z655-R1: Cell balancing. what kind of performance should we expect?
Part Number: BQ20Z655-R1
Other Parts Discussed in Thread: GPCCHEM
These are the steps being taken:
from a fully charged battery.
discharge and let rest for at least 2 hours.
charger the battery and let it rest for at least 5 hours.
the best we have gotten so far is 60mV between the highest and the lowest cell.
the most common is 80mV.
  • we are using the Samsung INR18650-25R LiNiMnCoO2.
    what I am looking for is someplace where the cell balancing is defined. something like a datasheet or a technical document that I can use in a report.
    we will be grouping cells that have close to the same internal resistance to remove that as a factor.
    what document or datasheet states the cell balancing performance?
  • Hi Tony,
    Cell balancing performance is dependent on a combination of the device algorithm, the parameter settings, and the external circuitry. It is not possible to specify this in a gauge datasheet since there are other dependencies.
    Additionally, the BQ20Z655-R1 balances based on the SOC of each cell which is very different from balancing based on cell voltage. There is a data flash parameter (Min Cell Deviation) that can be set to determine when to balance. I believe this device only balances during charging (some devices can also balance at rest) so the amount of balancing also depends on the rate of charge (faster charge means less time to balance) and the balance current.
    This is an older app note on cell balancing for this device family.
    https://www.ti.com/lit/an/slua340c/slua340c.pdf
    Matt
  • Matt,
      I guess my question should have been stated another way. what steps should be taken to make a raw pack to attach to our design?
    This is what we tried:
    take 4 raw cells from the battery manufacture that we measured internal impedance and matched to 0.002 ohms in the pack.
    make a pack.
    ataching them to the BQ20z655-R1 PCB
    doing a full charge (16.8V at 1.25A and stoping when the charge voltage is .125A)
    send the 0x0021 then the 0x0041 command to make a golden image and reset the BQ memory
    Discharge at 0.5A to stop at 10V pack V or 2.5V on any single cell
    wait 5 hours
    charge at 16.8V @ 1.25A stoping when current drops to .125A
    wait 2 hours
    discharge at 0.5A
    wait 5 hours
    after that golden cycle, we charge the packs to the 16.8V at 1.25A stoping change when the current dropped to 0.125A
    discharge the packs at the 0.5A rate stoping when the pack reaches 10V or a single cell drops to 2.5V. we measuring the pack capacity during this discharge.
    we did this on 8 packs to get an idea for a baseline. the cells were measured for internal impedance and paired with that in mind.
    6 of the 8 packs measured at 87 to 102% (102%, 101%, 93%, 90%, 90%, 87%) of the rated 2500mAh capacity
    cell 2 of the other two packs did not charge back to full and left the packs at 67% and 74%
    what should we be dong different? We are failing to understand why the packs did not act the same across the board.
  • your SLUA340 explains the method but not the way of our results.  We have a 4S battery pack design using the BQ20Z655-R1. When charging that pack, the cells are not balanced at all, and the capacity reported by the chip is from 65% to 101% after charging, and the cell charge is not balanced in the pack. We understand that your expert is looking into this with case CS0274536 and await a response from them.
  • Hello Tony,
    Can you provide an IVT file and a gg.csv file to show where the gauge reports 101%?
  • Kang Kang,
      The GG file is in the first post in the thread.
    I have some log files recorded when the cells were discharging on the Cadex battery controller.
    The cadex is the one stating the discharge was 101% of 2500 capacity.
  • Hello Tony,
    The attachment was removed. Can you help re-attach?
    Thanks!
  • Hello Tony,
    Could you upload the log and .gg files in .csv format for us to review? Thanks!
    Sincerely,
    Wyatt Keller
  • Hello Tony,
    I would try adjusting the min cell deviation for cell balancing issues using the formula from the TRM: Min Cell Deviation = R / (duty_cycle × V_avg) × 3.6 s/mAh
    For SOC jumps it is best to make sure you have selected the best matching chem ID for the battery you are using using the GPCCHEM tool.
    Sincerely,
    Wyatt Keller
  • Wyatt,
      the battery chem is set to 2044. This is the exact ID for the cells we are using.
    The min cell deviation is already set using the formula you posted above.
    any other suggestions?
  • Hello Tony,
    I think that's probably the best performance. How out of balance are the cells?
  • we made and tested 11 packs 8 of them were with older cells and 3 were with brand new cells..
    The balance on the older cells are from max to min is 85, 247, 60, 130, 145, 313,5, and 12mV.
    The packs were impedance matched prior to mating them up.  This is after 3-4 charge-discharge cycles.
    The new cells are looking like a consistent 2-4mV cell balance difference.
    does this mean that over time the balance is going to suffer?
  • Hello Tony,
    It is difficult to say. Over time, the cells will become more and more out of balance, but if you give it proper time, you could have better cell balancing performance.
    The device uses passive balancing, so it is not as fast as active balancing.
  • Are there other mitigating factors we can implement to provide the cells with the ability for longer shelf life? We have already set all of the above suggestions prior to making this post on the forum.
  • Hello Tony,
    For shelf life, other than the inherent self-discharge of the cells, you would need to reduce the power consumption from the board. For this bq20z device, you could put it in shutdown mode.
  • The primary issue is balancing. With the cells being up to 235mV offset in the first few days of the pack being put together this will limit the operating life of the pack.
    so far no one can tell us what is causing this and what the cure is.
  • Hello Tony,
    I think we may have exhausted theories at this point. If you have more clues to help us narrow down, please provide them here.
    Thanks!
  • what we need to answer is quite simple.
    after 5 charge rest discharge rest cycles on 4 different packs we get cell max - cell min voltages of 85, 247, 60, 130, 145, 313,5, and 12mV.
    Is this the expected behavior of the BQ20z655-R1 IC?
    if this is not the norm, what can we do to improve this?
    Do you have the log files that show this?
    The min voltages should not be 85 mV and max voltages should not be 247 mV.
    Can you attach prior starting gg.csv file and IVT log file?
  • the voltage stated is the difference between the MAX cell and MIN cell on 7 different battery packs.
    the .GG file is attached to this thread earlier in the discussion.
  • Hello Tony,
    Got it.
    Okay that's what I thought too from looking at the gg.csv files. Thank you for the clarification.
    Are you able to run a learning cycle on one of the packs and let it sit in relaxation to see if CB will eventually balance out the cells?
  • I ran a learning cycle on each of these packs.
    after that, I discharged/charged these packs 5 times before getting the reading from HIGH to LOW cell values at the end of the 5th charge period.
  • Hello Tony,
    Got it. Can you send me the 5 cycle log file?
    Thanks!
  • I dont have recorded data for alll of these.
    I do have some data on one of the packed recorded on the cadex battery tester.
    Duration (sec)	Status code	Status category	Status color	Pgm code	Pgm step	Pgm para	Pgm cycle	mV	mA	Temperature	Charge count	Discharge count	Thermal Chamber temperature	Thermal Chamber status	Capacity	Analog input 1	Analog input 2	Analog input 3	Analog input 4	Analog input warning 1	Analog input warning 2	Analog input warning 3	Analog input warning 4	Digital input 1	Digital input 2	Digital input 3	Digital input 4	Digital output 1	Digital output 2	Digital output 3	Digital output 4	Analog output 1	Analog output 2	SMB-mV	SMB-mA	SMB-K	SMB-alarm
    0	8	7	3	0	0	5	0	16385	0	26	0	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    3	8	7	3	0	0	5	0	16394	0	26	0	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    4	8	3	3	0	1	2	2	16398	5	26	0	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    52	8	3	3	0	1	2	2	16737	1250	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    112	8	3	3	0	1	2	2	16810	1175	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    172	8	3	3	0	1	2	2	16810	904	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    232	8	3	3	0	1	2	2	16810	738	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    292	8	3	3	0	1	2	2	16811	618	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    352	8	3	3	0	1	2	2	16810	527	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    412	8	3	3	0	1	2	2	16810	456	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    472	8	3	3	0	1	2	2	16811	399	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    532	8	3	3	0	1	2	2	16811	352	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    592	8	3	3	0	1	2	2	16810	312	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    652	8	3	3	0	1	2	2	16810	280	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    712	8	3	3	0	1	2	2	16810	249	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    772	8	3	3	0	1	2	2	16810	224	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    832	8	3	3	0	1	2	2	16810	203	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    892	8	3	3	0	1	2	2	16811	182	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    952	8	3	3	0	1	2	2	16811	166	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1012	8	3	3	0	1	2	2	16810	151	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1072	8	3	3	0	1	2	2	16810	139	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1132	8	3	3	0	1	2	2	16810	127	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1152	4	0	3	0	2	19	5	16789	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1192	4	0	3	0	2	19	5	16777	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1252	4	0	3	0	2	19	5	16767	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1312	4	0	3	0	2	19	5	16762	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1372	4	0	3	0	2	19	5	16758	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1432	4	0	3	0	2	19	5	16754	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1492	4	0	3	0	2	19	5	16750	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1552	4	0	3	0	2	19	5	16748	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1612	4	0	3	0	2	19	5	16745	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1672	4	0	3	0	2	19	5	16744	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1732	4	0	3	0	2	19	5	16742	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1792	4	0	3	0	2	19	5	16742	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1852	4	0	3	0	2	19	5	16740	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1912	4	0	3	0	2	19	5	16739	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1972	4	0	3	0	2	19	5	16737	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2032	4	0	3	0	2	19	5	16735	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2092	4	0	3	0	2	19	5	16735	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2152	4	0	3	0	2	19	5	16734	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2212	4	0	3	0	2	19	5	16732	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2272	4	0	3	0	2	19	5	16732	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2332	4	0	3	0	2	19	5	16731	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2392	4	0	3	0	2	19	5	16731	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2452	4	0	3	0	2	19	5	16730	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2512	4	0	3	0	2	19	5	16730	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2572	4	0	3	0	2	19	5	16728	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2632	4	0	3	0	2	19	5	16727	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2692	4	0	3	0	2	19	5	16727	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2752	4	0	3	0	2	19	5	16726	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2812	4	0	3	0	2	19	5	16726	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2872	4	0	3	0	2	19	5	16726	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2932	4	0	3	0	2	19	5	16725	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2992	4	0	3	0	2	19	5	16724	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3052	4	0	3	0	2	19	5	16725	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3112	4	0	3	0	2	19	5	16724	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3172	4	0	3	0	2	19	5	16724	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3232	4	0	3	0	2	19	5	16723	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3292	4	0	3	0	2	19	5	16723	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3352	4	0	3	0	2	19	5	16722	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3412	4	0	3	0	2	19	5	16722	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3472	4	0	3	0	2	19	5	16723	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3532	4	0	3	0	2	19	5	16722	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3592	4	0	3	0	2	19	5	16722	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3652	4	0	3	0	2	19	5	16721	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3712	4	0	3	0	2	19	5	16721	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3772	4	0	3	0	2	19	5	16721	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3832	4	0	3	0	2	19	5	16721	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3892	4	0	3	0	2	19	5	16720	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3952	4	0	3	0	2	19	5	16720	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4012	4	0	3	0	2	19	5	16719	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4072	4	0	3	0	2	19	5	16720	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4132	4	0	3	0	2	19	5	16720	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4192	4	0	3	0	2	19	5	16719	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4252	4	0	3	0	2	19	5	16719	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4312	4	0	3	0	2	19	5	16719	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4372	4	0	3	0	2	19	5	16717	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4432	4	0	3	0	2	19	5	16718	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4492	4	0	3	0	2	19	5	16717	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4552	4	0	3	0	2	19	5	16717	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4612	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4672	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4732	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4792	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4852	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4912	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4972	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5032	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5092	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5152	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5212	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5272	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5332	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5392	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5452	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5512	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5572	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5632	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5692	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5752	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5812	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5872	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5932	4	0	3	0	2	19	5	16712	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5992	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6052	4	0	3	0	2	19	5	16712	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6112	4	0	3	0	2	19	5	16712	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6172	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6232	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6292	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6352	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6412	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6472	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6532	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6592	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6652	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6712	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6772	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6832	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6892	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6952	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7012	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7072	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7132	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7192	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7252	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7312	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7372	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7432	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7492	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7552	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7612	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7672	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7732	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7792	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7852	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7912	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7972	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8032	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8092	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8152	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8212	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8272	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8332	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8352	8	6	3	0	3	7	1	16620	-499	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8392	8	6	3	0	3	7	1	16564	-498	26	1	1	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8452	8	6	3	0	3	7	1	16521	-500	26	1	1	0	0	0	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8512	8	6	3	0	3	7	1	16486	-500	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8572	8	6	3	0	3	7	1	16457	-499	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8632	8	6	3	0	3	7	1	16430	-499	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8692	8	6	3	0	3	7	1	16406	-501	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8752	8	6	3	0	3	7	1	16384	-499	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8812	8	6	3	0	3	7	1	16363	-498	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8872	8	6	3	0	3	7	1	16343	-499	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8932	8	6	3	0	3	7	1	16325	-498	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8992	8	6	3	0	3	7	1	16308	-499	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9052	8	6	3	0	3	7	1	16292	-498	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9112	8	6	3	0	3	7	1	16276	-501	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9172	8	6	3	0	3	7	1	16261	-501	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9232	8	6	3	0	3	7	1	16245	-499	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9292	8	6	3	0	3	7	1	16233	-499	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9352	8	6	3	0	3	7	1	16219	-499	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9412	8	6	3	0	3	7	1	16205	-500	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9472	8	6	3	0	3	7	1	16192	-500	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9532	8	6	3	0	3	7	1	16178	-500	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9592	8	6	3	0	3	7	1	16166	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9652	8	6	3	0	3	7	1	16153	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9712	8	6	3	0	3	7	1	16139	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9772	8	6	3	0	3	7	1	16129	-500	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9832	8	6	3	0	3	7	1	16116	-499	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9892	8	6	3	0	3	7	1	16103	-499	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9952	8	6	3	0	3	7	1	16091	-499	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10012	8	6	3	0	3	7	1	16079	-498	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10072	8	6	3	0	3	7	1	16066	-500	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10132	8	6	3	0	3	7	1	16055	-499	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10192	8	6	3	0	3	7	1	16042	-500	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10252	8	6	3	0	3	7	1	16030	-500	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10312	8	6	3	0	3	7	1	16018	-500	26	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10372	8	6	3	0	3	7	1	16006	-499	26	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10432	8	6	3	0	3	7	1	15993	-501	27	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10492	8	6	3	0	3	7	1	15981	-499	27	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10552	8	6	3	0	3	7	1	15969	-500	27	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10612	8	6	3	0	3	7	1	15955	-500	27	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10672	8	6	3	0	3	7	1	15944	-499	27	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10732	8	6	3	0	3	7	1	15930	-500	27	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10792	8	6	3	0	3	7	1	15918	-499	27	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10852	8	6	3	0	3	7	1	15905	-499	27	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10912	8	6	3	0	3	7	1	15892	-499	27	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10972	8	6	3	0	3	7	1	15880	-500	27	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11032	8	6	3	0	3	7	1	15865	-499	27	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11092	8	6	3	0	3	7	1	15851	-500	27	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11152	8	6	3	0	3	7	1	15838	-499	27	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11212	8	6	3	0	3	7	1	15825	-500	27	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11272	8	6	3	0	3	7	1	15811	-499	27	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11332	8	6	3	0	3	7	1	15797	-500	27	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11392	8	6	3	0	3	7	1	15783	-499	27	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11452	8	6	3	0	3	7	1	15769	-500	27	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11512	8	6	3	0	3	7	1	15756	-499	27	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11572	8	6	3	0	3	7	1	15741	-500	27	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11632	8	6	3	0	3	7	1	15727	-499	27	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11692	8	6	3	0	3	7	1	15714	-499	27	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11752	8	6	3	0	3	7	1	15700	-500	27	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11812	8	6	3	0	3	7	1	15686	-498	27	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11872	8	6	3	0	3	7	1	15672	-499	27	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11932	8	6	3	0	3	7	1	15659	-498	27	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11992	8	6	3	0	3	7	1	15645	-500	27	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12052	8	6	3	0	3	7	1	15632	-500	27	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12112	8	6	3	0	3	7	1	15619	-498	27	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12172	8	6	3	0	3	7	1	15605	-499	27	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12232	8	6	3	0	3	7	1	15592	-500	27	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12292	8	6	3	0	3	7	1	15579	-499	27	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12352	8	6	3	0	3	7	1	15565	-502	27	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12412	8	6	3	0	3	7	1	15554	-499	27	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12472	8	6	3	0	3	7	1	15540	-500	27	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12532	8	6	3	0	3	7	1	15526	-499	27	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12592	8	6	3	0	3	7	1	15513	-498	27	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12652	8	6	3	0	3	7	1	15501	-499	27	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12712	8	6	3	0	3	7	1	15488	-499	27	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12772	8	6	3	0	3	7	1	15475	-500	27	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12832	8	6	3	0	3	7	1	15462	-500	27	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12892	8	6	3	0	3	7	1	15450	-501	27	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12952	8	6	3	0	3	7	1	15437	-499	27	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13012	8	6	3	0	3	7	1	15425	-499	27	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13072	8	6	3	0	3	7	1	15413	-500	27	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13132	8	6	3	0	3	7	1	15400	-500	27	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13192	8	6	3	0	3	7	1	15387	-499	27	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13252	8	6	3	0	3	7	1	15375	-499	27	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13312	8	6	3	0	3	7	1	15362	-499	27	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13372	8	6	3	0	3	7	1	15350	-500	27	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13432	8	6	3	0	3	7	1	15338	-500	27	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13492	8	6	3	0	3	7	1	15326	-500	27	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13552	8	6	3	0	3	7	1	15312	-499	27	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13612	8	6	3	0	3	7	1	15301	-500	27	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13672	8	6	3	0	3	7	1	15288	-499	27	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13732	8	6	3	0	3	7	1	15275	-499	27	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13792	8	6	3	0	3	7	1	15263	-500	27	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13852	8	6	3	0	3	7	1	15250	-499	27	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13912	8	6	3	0	3	7	1	15237	-499	27	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13972	8	6	3	0	3	7	1	15225	-499	27	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14032	8	6	3	0	3	7	1	15212	-501	27	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14092	8	6	3	0	3	7	1	15200	-500	27	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14152	8	6	3	0	3	7	1	15186	-499	27	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14212	8	6	3	0	3	7	1	15174	-500	27	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14272	8	6	3	0	3	7	1	15161	-501	27	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14332	8	6	3	0	3	7	1	15148	-500	27	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14392	8	6	3	0	3	7	1	15135	-499	27	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14452	8	6	3	0	3	7	1	15122	-500	27	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14512	8	6	3	0	3	7	1	15110	-499	27	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14572	8	6	3	0	3	7	1	15097	-499	27	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14632	8	6	3	0	3	7	1	15084	-501	27	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14692	8	6	3	0	3	7	1	15072	-499	27	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14752	8	6	3	0	3	7	1	15058	-501	27	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14812	8	6	3	0	3	7	1	15045	-499	27	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14872	8	6	3	0	3	7	1	15033	-498	27	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14932	8	6	3	0	3	7	1	15020	-499	27	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14992	8	6	3	0	3	7	1	15007	-498	27	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15052	8	6	3	0	3	7	1	14994	-500	27	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15112	8	6	3	0	3	7	1	14982	-499	27	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15172	8	6	3	0	3	7	1	14969	-500	27	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15232	8	6	3	0	3	7	1	14956	-498	27	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15292	8	6	3	0	3	7	1	14945	-499	27	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15352	8	6	3	0	3	7	1	14932	-500	27	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15412	8	6	3	0	3	7	1	14918	-500	27	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15472	8	6	3	0	3	7	1	14907	-500	27	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15532	8	6	3	0	3	7	1	14895	-499	27	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15592	8	6	3	0	3	7	1	14882	-500	27	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15652	8	6	3	0	3	7	1	14870	-499	27	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15712	8	6	3	0	3	7	1	14858	-499	27	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15772	8	6	3	0	3	7	1	14845	-500	27	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15832	8	6	3	0	3	7	1	14834	-499	27	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15892	8	6	3	0	3	7	1	14822	-499	27	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15952	8	6	3	0	3	7	1	14810	-500	27	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16012	8	6	3	0	3	7	1	14799	-499	27	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16072	8	6	3	0	3	7	1	14788	-499	27	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16132	8	6	3	0	3	7	1	14775	-499	27	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16192	8	6	3	0	3	7	1	14764	-499	27	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16252	8	6	3	0	3	7	1	14753	-501	27	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16312	8	6	3	0	3	7	1	14740	-499	27	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16372	8	6	3	0	3	7	1	14730	-500	27	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16432	8	6	3	0	3	7	1	14718	-499	27	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16492	8	6	3	0	3	7	1	14707	-500	27	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16552	8	6	3	0	3	7	1	14697	-499	27	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16612	8	6	3	0	3	7	1	14685	-501	27	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16672	8	6	3	0	3	7	1	14675	-499	27	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16732	8	6	3	0	3	7	1	14664	-500	27	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16792	8	6	3	0	3	7	1	14653	-500	27	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16852	8	6	3	0	3	7	1	14643	-500	27	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16912	8	6	3	0	3	7	1	14632	-499	27	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16972	8	6	3	0	3	7	1	14622	-498	27	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17032	8	6	3	0	3	7	1	14612	-501	27	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17092	8	6	3	0	3	7	1	14602	-500	27	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17152	8	6	3	0	3	7	1	14592	-500	27	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17212	8	6	3	0	3	7	1	14582	-500	27	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17272	8	6	3	0	3	7	1	14572	-499	27	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17332	8	6	3	0	3	7	1	14561	-499	27	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17392	8	6	3	0	3	7	1	14553	-499	27	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17452	8	6	3	0	3	7	1	14543	-498	27	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17512	8	6	3	0	3	7	1	14534	-500	27	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17572	8	6	3	0	3	7	1	14524	-499	27	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17632	8	6	3	0	3	7	1	14516	-500	27	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17692	8	6	3	0	3	7	1	14506	-499	27	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17752	8	6	3	0	3	7	1	14498	-499	27	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17812	8	6	3	0	3	7	1	14488	-499	27	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17872	8	6	3	0	3	7	1	14480	-500	27	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17932	8	6	3	0	3	7	1	14471	-498	27	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17992	8	6	3	0	3	7	1	14462	-500	27	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18052	8	6	3	0	3	7	1	14453	-500	27	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18112	8	6	3	0	3	7	1	14446	-499	27	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18172	8	6	3	0	3	7	1	14437	-498	27	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18232	8	6	3	0	3	7	1	14429	-499	27	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18292	8	6	3	0	3	7	1	14421	-499	27	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18352	8	6	3	0	3	7	1	14413	-500	27	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18412	8	6	3	0	3	7	1	14405	-498	27	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18472	8	6	3	0	3	7	1	14397	-499	27	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18532	8	6	3	0	3	7	1	14390	-500	27	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18592	8	6	3	0	3	7	1	14382	-498	27	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18652	8	6	3	0	3	7	1	14375	-499	27	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18712	8	6	3	0	3	7	1	14367	-499	27	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18772	8	6	3	0	3	7	1	14359	-500	27	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18832	8	6	3	0	3	7	1	14352	-499	27	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18892	8	6	3	0	3	7	1	14345	-499	27	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18952	8	6	3	0	3	7	1	14337	-499	27	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19012	8	6	3	0	3	7	1	14330	-500	27	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19072	8	6	3	0	3	7	1	14322	-500	27	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19132	8	6	3	0	3	7	1	14315	-498	27	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19192	8	6	3	0	3	7	1	14307	-499	27	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19252	8	6	3	0	3	7	1	14302	-499	27	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19312	8	6	3	0	3	7	1	14294	-499	27	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19372	8	6	3	0	3	7	1	14287	-500	27	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19432	8	6	3	0	3	7	1	14280	-500	27	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19492	8	6	3	0	3	7	1	14272	-499	27	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19552	8	6	3	0	3	7	1	14266	-500	27	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19612	8	6	3	0	3	7	1	14259	-499	27	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19672	8	6	3	0	3	7	1	14252	-499	27	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19732	8	6	3	0	3	7	1	14245	-499	27	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19792	8	6	3	0	3	7	1	14238	-499	27	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19852	8	6	3	0	3	7	1	14232	-501	27	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19912	8	6	3	0	3	7	1	14224	-500	27	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19972	8	6	3	0	3	7	1	14217	-500	27	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20032	8	6	3	0	3	7	1	14211	-500	27	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20092	8	6	3	0	3	7	1	14203	-497	27	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20152	8	6	3	0	3	7	1	14197	-499	27	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20212	8	6	3	0	3	7	1	14189	-499	27	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20272	8	6	3	0	3	7	1	14182	-499	27	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20332	8	6	3	0	3	7	1	14176	-498	27	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20392	8	6	3	0	3	7	1	14168	-498	27	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20452	8	6	3	0	3	7	1	14161	-499	27	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20512	8	6	3	0	3	7	1	14154	-500	27	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20572	8	6	3	0	3	7	1	14146	-499	27	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20632	8	6	3	0	3	7	1	14140	-499	27	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20692	8	6	3	0	3	7	1	14132	-500	27	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20752	8	6	3	0	3	7	1	14124	-500	27	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20812	8	6	3	0	3	7	1	14117	-500	27	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20872	8	6	3	0	3	7	1	14109	-499	27	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20932	8	6	3	0	3	7	1	14100	-501	27	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20992	8	6	3	0	3	7	1	14092	-498	27	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21052	8	6	3	0	3	7	1	14085	-500	27	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21112	8	6	3	0	3	7	1	14076	-499	27	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21172	8	6	3	0	3	7	1	14068	-500	27	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21232	8	6	3	0	3	7	1	14058	-500	27	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21292	8	6	3	0	3	7	1	14049	-499	27	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21352	8	6	3	0	3	7	1	14039	-499	27	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21412	8	6	3	0	3	7	1	14030	-499	27	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21472	8	6	3	0	3	7	1	14020	-498	27	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21532	8	6	3	0	3	7	1	14010	-499	27	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21592	8	6	3	0	3	7	1	13999	-499	28	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21652	8	6	3	0	3	7	1	13987	-499	28	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21712	8	6	3	0	3	7	1	13977	-500	28	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21772	8	6	3	0	3	7	1	13964	-500	28	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21832	8	6	3	0	3	7	1	13952	-498	28	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21892	8	6	3	0	3	7	1	13941	-499	28	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21952	8	6	3	0	3	7	1	13928	-499	28	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22012	8	6	3	0	3	7	1	13914	-498	28	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22072	8	6	3	0	3	7	1	13900	-500	28	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22132	8	6	3	0	3	7	1	13887	-499	28	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22192	8	6	3	0	3	7	1	13872	-499	28	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22252	8	6	3	0	3	7	1	13857	-499	28	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22312	8	6	3	0	3	7	1	13842	-500	28	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22372	8	6	3	0	3	7	1	13828	-500	28	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22432	8	6	3	0	3	7	1	13813	-499	28	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22492	8	6	3	0	3	7	1	13799	-500	28	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22552	8	6	3	0	3	7	1	13785	-499	28	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22612	8	6	3	0	3	7	1	13771	-500	28	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22672	8	6	3	0	3	7	1	13760	-498	28	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22732	8	6	3	0	3	7	1	13748	-499	28	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22792	8	6	3	0	3	7	1	13736	-499	28	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22852	8	6	3	0	3	7	1	13725	-501	28	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22912	8	6	3	0	3	7	1	13713	-501	28	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22972	8	6	3	0	3	7	1	13700	-500	28	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23032	8	6	3	0	3	7	1	13688	-498	28	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23092	8	6	3	0	3	7	1	13676	-499	28	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23152	8	6	3	0	3	7	1	13662	-499	28	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23212	8	6	3	0	3	7	1	13649	-500	28	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23272	8	6	3	0	3	7	1	13636	-500	28	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23332	8	6	3	0	3	7	1	13621	-500	28	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23392	8	6	3	0	3	7	1	13607	-500	28	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23452	8	6	3	0	3	7	1	13591	-499	28	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23512	8	6	3	0	3	7	1	13576	-499	28	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23572	8	6	3	0	3	7	1	13561	-499	28	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23632	8	6	3	0	3	7	1	13544	-499	28	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23692	8	6	3	0	3	7	1	13526	-498	28	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23755	8	6	3	0	3	7	1	13508	-499	28	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23815	8	6	3	0	3	7	1	13488	-500	28	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23875	8	6	3	0	3	7	1	13466	-499	28	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23935	8	6	3	0	3	7	1	13442	-500	28	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23995	8	6	3	0	3	7	1	13414	-499	28	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24055	8	6	3	0	3	7	1	13383	-499	28	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24115	8	6	3	0	3	7	1	13347	-500	28	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24175	8	6	3	0	3	7	1	13306	-499	28	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24235	8	6	3	0	3	7	1	13261	-498	28	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24295	8	6	3	0	3	7	1	13209	-500	28	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24355	8	6	3	0	3	7	1	13151	-499	28	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24415	8	6	3	0	3	7	1	13088	-498	28	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24478	8	6	3	0	3	7	1	13016	-499	28	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24538	8	6	3	0	3	7	1	12943	-499	28	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24598	8	6	3	0	3	7	1	12865	-500	28	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24658	8	6	3	0	3	7	1	12781	-499	28	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24718	8	6	3	0	3	7	1	12690	-498	28	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24781	8	6	3	0	3	7	1	12585	-500	28	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24841	8	6	3	0	3	7	1	12478	-498	28	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24901	8	6	3	0	3	7	1	12359	-500	28	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24961	8	6	3	0	3	7	1	12225	-500	28	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25021	8	6	3	0	3	7	1	12072	-499	28	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25081	8	6	3	0	3	7	1	11885	-498	29	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25141	8	6	3	0	3	7	1	11672	-499	29	1	1	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25182	9	10	4	0	0	17	0	0	0	29	0	0	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    25182	9	0	4	0	0	16	0	0	0	29	0	0	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    1	8	7	3	0	0	5	0	16398	0	25	0	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    4	8	7	3	0	0	5	2	16402	0	25	0	0	0	0	0	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5	8	3	3	0	1	2	2	16555	952	25	0	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9	8	3	3	0	1	2	2	16638	1250	25	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    69	8	3	3	0	1	2	2	16776	1246	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    129	8	3	3	0	1	2	2	16796	971	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    189	8	3	3	0	1	2	2	16797	768	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    249	8	3	3	0	1	2	2	16796	633	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    309	8	3	3	0	1	2	2	16796	534	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    369	8	3	3	0	1	2	2	16796	460	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    429	8	3	3	0	1	2	2	16797	400	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    489	8	3	3	0	1	2	2	16796	352	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    549	8	3	3	0	1	2	2	16797	312	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    609	8	3	3	0	1	2	2	16797	277	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    669	8	3	3	0	1	2	2	16797	248	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    729	8	3	3	0	1	2	2	16797	223	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    789	8	3	3	0	1	2	2	16797	200	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    849	8	3	3	0	1	2	2	16796	183	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    909	8	3	3	0	1	2	2	16797	166	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    969	8	3	3	0	1	2	2	16796	151	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1029	8	3	3	0	1	2	2	16797	138	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1089	8	3	3	0	1	2	2	16797	126	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1095	4	0	3	0	2	19	5	16790	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1149	4	0	3	0	2	19	5	16760	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1209	4	0	3	0	2	19	5	16751	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1269	4	0	3	0	2	19	5	16746	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1329	4	0	3	0	2	19	5	16741	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1389	4	0	3	0	2	19	5	16737	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1449	4	0	3	0	2	19	5	16734	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1509	4	0	3	0	2	19	5	16731	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1569	4	0	3	0	2	19	5	16730	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1629	4	0	3	0	2	19	5	16727	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1689	4	0	3	0	2	19	5	16725	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1749	4	0	3	0	2	19	5	16724	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1809	4	0	3	0	2	19	5	16722	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1869	4	0	3	0	2	19	5	16720	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1929	4	0	3	0	2	19	5	16719	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    1989	4	0	3	0	2	19	5	16718	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2049	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2109	4	0	3	0	2	19	5	16716	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2169	4	0	3	0	2	19	5	16715	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2229	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2289	4	0	3	0	2	19	5	16714	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2349	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2409	4	0	3	0	2	19	5	16713	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2469	4	0	3	0	2	19	5	16712	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2529	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2589	4	0	3	0	2	19	5	16711	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2649	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2709	4	0	3	0	2	19	5	16710	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2769	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2829	4	0	3	0	2	19	5	16709	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2889	4	0	3	0	2	19	5	16708	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    2949	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3009	4	0	3	0	2	19	5	16707	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3069	4	0	3	0	2	19	5	16706	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3129	4	0	3	0	2	19	5	16705	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3189	4	0	3	0	2	19	5	16705	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3249	4	0	3	0	2	19	5	16705	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3309	4	0	3	0	2	19	5	16704	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3369	4	0	3	0	2	19	5	16704	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3429	4	0	3	0	2	19	5	16703	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3489	4	0	3	0	2	19	5	16704	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3549	4	0	3	0	2	19	5	16704	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3609	4	0	3	0	2	19	5	16703	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3669	4	0	3	0	2	19	5	16703	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3729	4	0	3	0	2	19	5	16703	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3789	4	0	3	0	2	19	5	16702	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3849	4	0	3	0	2	19	5	16702	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3909	4	0	3	0	2	19	5	16702	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    3969	4	0	3	0	2	19	5	16701	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4029	4	0	3	0	2	19	5	16701	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4089	4	0	3	0	2	19	5	16700	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4149	4	0	3	0	2	19	5	16700	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4209	4	0	3	0	2	19	5	16700	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4269	4	0	3	0	2	19	5	16700	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4329	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4389	4	0	3	0	2	19	5	16700	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4449	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4509	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4569	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4629	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4689	4	0	3	0	2	19	5	16698	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4749	4	0	3	0	2	19	5	16699	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4809	4	0	3	0	2	19	5	16698	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4869	4	0	3	0	2	19	5	16698	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4929	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    4989	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5049	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5109	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5169	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5229	4	0	3	0	2	19	5	16697	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5289	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5349	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5409	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5469	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5529	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5589	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5649	4	0	3	0	2	19	5	16696	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5709	4	0	3	0	2	19	5	16695	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5769	4	0	3	0	2	19	5	16695	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5829	4	0	3	0	2	19	5	16695	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5889	4	0	3	0	2	19	5	16695	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    5949	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6009	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6069	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6129	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6189	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6249	4	0	3	0	2	19	5	16694	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6309	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6369	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6429	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6489	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6549	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6609	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6669	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6729	4	0	3	0	2	19	5	16693	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6789	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6849	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6909	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    6969	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7029	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7089	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7149	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7209	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7269	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7329	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7389	4	0	3	0	2	19	5	16692	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7449	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7509	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7569	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7629	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7689	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7749	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7809	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7869	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7929	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    7989	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8049	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8109	4	0	3	0	2	19	5	16691	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8169	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8229	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8289	4	0	3	0	2	19	5	16690	0	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8295	8	6	3	0	3	7	1	16684	-40	26	1	0	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8349	8	6	3	0	3	7	1	16536	-499	26	1	1	0	0	255	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8409	8	6	3	0	3	7	1	16495	-500	26	1	1	0	0	0	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8469	8	6	3	0	3	7	1	16461	-499	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8529	8	6	3	0	3	7	1	16432	-499	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8589	8	6	3	0	3	7	1	16406	-499	26	1	1	0	0	1	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8649	8	6	3	0	3	7	1	16382	-499	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8709	8	6	3	0	3	7	1	16359	-500	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8769	8	6	3	0	3	7	1	16339	-498	26	1	1	0	0	2	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8829	8	6	3	0	3	7	1	16320	-499	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8889	8	6	3	0	3	7	1	16301	-499	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    8949	8	6	3	0	3	7	1	16285	-499	26	1	1	0	0	3	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9009	8	6	3	0	3	7	1	16269	-500	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9069	8	6	3	0	3	7	1	16253	-499	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9129	8	6	3	0	3	7	1	16239	-499	26	1	1	0	0	4	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9189	8	6	3	0	3	7	1	16225	-500	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9249	8	6	3	0	3	7	1	16211	-498	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9309	8	6	3	0	3	7	1	16197	-500	26	1	1	0	0	5	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9369	8	6	3	0	3	7	1	16184	-499	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9429	8	6	3	0	3	7	1	16171	-500	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9489	8	6	3	0	3	7	1	16158	-499	26	1	1	0	0	6	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9549	8	6	3	0	3	7	1	16146	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9609	8	6	3	0	3	7	1	16133	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9669	8	6	3	0	3	7	1	16121	-499	26	1	1	0	0	7	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9729	8	6	3	0	3	7	1	16109	-499	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9789	8	6	3	0	3	7	1	16097	-499	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9849	8	6	3	0	3	7	1	16084	-499	26	1	1	0	0	8	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9909	8	6	3	0	3	7	1	16072	-499	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    9969	8	6	3	0	3	7	1	16061	-499	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10029	8	6	3	0	3	7	1	16048	-498	26	1	1	0	0	9	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10089	8	6	3	0	3	7	1	16037	-499	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10149	8	6	3	0	3	7	1	16025	-499	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10209	8	6	3	0	3	7	1	16013	-499	26	1	1	0	0	10	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10269	8	6	3	0	3	7	1	16001	-500	26	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10329	8	6	3	0	3	7	1	15990	-498	26	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10389	8	6	3	0	3	7	1	15977	-500	26	1	1	0	0	11	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10449	8	6	3	0	3	7	1	15965	-499	26	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10509	8	6	3	0	3	7	1	15954	-499	26	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10569	8	6	3	0	3	7	1	15941	-499	26	1	1	0	0	12	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10629	8	6	3	0	3	7	1	15929	-499	26	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10689	8	6	3	0	3	7	1	15917	-499	26	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10749	8	6	3	0	3	7	1	15904	-499	26	1	1	0	0	13	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10809	8	6	3	0	3	7	1	15891	-499	26	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10869	8	6	3	0	3	7	1	15879	-500	26	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10929	8	6	3	0	3	7	1	15866	-499	26	1	1	0	0	14	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    10989	8	6	3	0	3	7	1	15852	-499	26	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11049	8	6	3	0	3	7	1	15839	-500	26	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11109	8	6	3	0	3	7	1	15825	-500	26	1	1	0	0	15	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11169	8	6	3	0	3	7	1	15811	-499	26	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11229	8	6	3	0	3	7	1	15797	-499	26	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11289	8	6	3	0	3	7	1	15783	-498	26	1	1	0	0	16	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11349	8	6	3	0	3	7	1	15770	-499	26	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11409	8	6	3	0	3	7	1	15757	-500	26	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11469	8	6	3	0	3	7	1	15742	-500	26	1	1	0	0	17	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11529	8	6	3	0	3	7	1	15728	-501	26	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11589	8	6	3	0	3	7	1	15715	-498	26	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11649	8	6	3	0	3	7	1	15702	-500	26	1	1	0	0	18	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11709	8	6	3	0	3	7	1	15688	-500	26	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11769	8	6	3	0	3	7	1	15674	-499	26	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11829	8	6	3	0	3	7	1	15661	-499	26	1	1	0	0	19	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11889	8	6	3	0	3	7	1	15648	-500	26	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    11949	8	6	3	0	3	7	1	15634	-500	26	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12009	8	6	3	0	3	7	1	15620	-499	26	1	1	0	0	20	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12069	8	6	3	0	3	7	1	15607	-499	26	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12129	8	6	3	0	3	7	1	15594	-500	26	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12189	8	6	3	0	3	7	1	15580	-499	26	1	1	0	0	21	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12249	8	6	3	0	3	7	1	15568	-499	26	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12309	8	6	3	0	3	7	1	15554	-499	26	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12369	8	6	3	0	3	7	1	15540	-499	26	1	1	0	0	22	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12429	8	6	3	0	3	7	1	15528	-500	26	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12489	8	6	3	0	3	7	1	15515	-499	26	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12549	8	6	3	0	3	7	1	15503	-499	26	1	1	0	0	23	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12609	8	6	3	0	3	7	1	15490	-500	26	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12669	8	6	3	0	3	7	1	15477	-500	26	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12729	8	6	3	0	3	7	1	15465	-500	26	1	1	0	0	24	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12789	8	6	3	0	3	7	1	15452	-499	26	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12849	8	6	3	0	3	7	1	15440	-500	26	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12909	8	6	3	0	3	7	1	15429	-500	26	1	1	0	0	25	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    12969	8	6	3	0	3	7	1	15416	-500	26	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13029	8	6	3	0	3	7	1	15402	-500	26	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13089	8	6	3	0	3	7	1	15391	-499	26	1	1	0	0	26	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13149	8	6	3	0	3	7	1	15379	-499	26	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13209	8	6	3	0	3	7	1	15366	-500	26	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13269	8	6	3	0	3	7	1	15354	-499	26	1	1	0	0	27	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13329	8	6	3	0	3	7	1	15341	-498	26	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13389	8	6	3	0	3	7	1	15328	-497	26	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13449	8	6	3	0	3	7	1	15316	-500	26	1	1	0	0	28	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13509	8	6	3	0	3	7	1	15304	-499	26	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13569	8	6	3	0	3	7	1	15292	-500	26	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13629	8	6	3	0	3	7	1	15279	-500	26	1	1	0	0	29	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13689	8	6	3	0	3	7	1	15266	-498	26	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13749	8	6	3	0	3	7	1	15254	-499	26	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13809	8	6	3	0	3	7	1	15241	-499	26	1	1	0	0	30	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13869	8	6	3	0	3	7	1	15228	-499	26	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13929	8	6	3	0	3	7	1	15216	-500	26	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    13989	8	6	3	0	3	7	1	15203	-499	26	1	1	0	0	31	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14049	8	6	3	0	3	7	1	15190	-500	26	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14109	8	6	3	0	3	7	1	15178	-500	26	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14169	8	6	3	0	3	7	1	15165	-500	26	1	1	0	0	32	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14229	8	6	3	0	3	7	1	15151	-499	26	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14289	8	6	3	0	3	7	1	15139	-499	26	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14349	8	6	3	0	3	7	1	15127	-499	26	1	1	0	0	33	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14409	8	6	3	0	3	7	1	15113	-499	26	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14469	8	6	3	0	3	7	1	15100	-499	26	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14529	8	6	3	0	3	7	1	15089	-499	26	1	1	0	0	34	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14589	8	6	3	0	3	7	1	15076	-498	26	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14649	8	6	3	0	3	7	1	15063	-500	26	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14709	8	6	3	0	3	7	1	15050	-499	26	1	1	0	0	35	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14769	8	6	3	0	3	7	1	15037	-501	26	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14829	8	6	3	0	3	7	1	15025	-499	26	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14889	8	6	3	0	3	7	1	15012	-500	26	1	1	0	0	36	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    14949	8	6	3	0	3	7	1	15000	-499	26	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15009	8	6	3	0	3	7	1	14987	-500	26	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15069	8	6	3	0	3	7	1	14975	-499	26	1	1	0	0	37	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15129	8	6	3	0	3	7	1	14962	-499	26	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15189	8	6	3	0	3	7	1	14950	-500	26	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15249	8	6	3	0	3	7	1	14936	-499	26	1	1	0	0	38	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15309	8	6	3	0	3	7	1	14925	-499	26	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15369	8	6	3	0	3	7	1	14913	-499	26	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15429	8	6	3	0	3	7	1	14899	-500	26	1	1	0	0	39	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15489	8	6	3	0	3	7	1	14888	-499	26	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15549	8	6	3	0	3	7	1	14876	-499	26	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15609	8	6	3	0	3	7	1	14863	-500	26	1	1	0	0	40	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15669	8	6	3	0	3	7	1	14851	-500	26	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15729	8	6	3	0	3	7	1	14839	-500	26	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15789	8	6	3	0	3	7	1	14827	-499	26	1	1	0	0	41	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15849	8	6	3	0	3	7	1	14815	-499	26	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15909	8	6	3	0	3	7	1	14804	-501	26	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    15969	8	6	3	0	3	7	1	14792	-499	26	1	1	0	0	42	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16029	8	6	3	0	3	7	1	14780	-499	26	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16089	8	6	3	0	3	7	1	14769	-500	26	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16149	8	6	3	0	3	7	1	14757	-499	26	1	1	0	0	43	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16209	8	6	3	0	3	7	1	14746	-499	26	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16269	8	6	3	0	3	7	1	14735	-499	26	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16329	8	6	3	0	3	7	1	14723	-499	26	1	1	0	0	44	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16389	8	6	3	0	3	7	1	14713	-500	26	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16449	8	6	3	0	3	7	1	14701	-499	26	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16509	8	6	3	0	3	7	1	14691	-500	26	1	1	0	0	45	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16569	8	6	3	0	3	7	1	14679	-499	26	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16629	8	6	3	0	3	7	1	14669	-500	26	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16689	8	6	3	0	3	7	1	14659	-500	26	1	1	0	0	46	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16749	8	6	3	0	3	7	1	14648	-498	26	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16809	8	6	3	0	3	7	1	14638	-500	26	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16869	8	6	3	0	3	7	1	14627	-499	26	1	1	0	0	47	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16929	8	6	3	0	3	7	1	14616	-498	26	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    16989	8	6	3	0	3	7	1	14607	-498	26	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17049	8	6	3	0	3	7	1	14597	-500	26	1	1	0	0	48	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17109	8	6	3	0	3	7	1	14587	-498	26	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17169	8	6	3	0	3	7	1	14576	-500	26	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17229	8	6	3	0	3	7	1	14567	-500	26	1	1	0	0	49	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17289	8	6	3	0	3	7	1	14557	-498	26	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17349	8	6	3	0	3	7	1	14548	-498	26	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17409	8	6	3	0	3	7	1	14539	-500	26	1	1	0	0	50	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17469	8	6	3	0	3	7	1	14529	-499	26	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17529	8	6	3	0	3	7	1	14519	-499	26	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17589	8	6	3	0	3	7	1	14510	-500	26	1	1	0	0	51	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17649	8	6	3	0	3	7	1	14501	-501	26	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17709	8	6	3	0	3	7	1	14492	-500	26	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17769	8	6	3	0	3	7	1	14483	-499	26	1	1	0	0	52	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17829	8	6	3	0	3	7	1	14475	-500	26	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17889	8	6	3	0	3	7	1	14466	-499	26	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    17949	8	6	3	0	3	7	1	14458	-499	26	1	1	0	0	53	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18009	8	6	3	0	3	7	1	14449	-499	26	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18069	8	6	3	0	3	7	1	14441	-499	26	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18129	8	6	3	0	3	7	1	14432	-499	26	1	1	0	0	54	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18189	8	6	3	0	3	7	1	14425	-499	26	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18249	8	6	3	0	3	7	1	14416	-499	26	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18309	8	6	3	0	3	7	1	14410	-499	26	1	1	0	0	55	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18369	8	6	3	0	3	7	1	14401	-499	26	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18429	8	6	3	0	3	7	1	14393	-500	26	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18489	8	6	3	0	3	7	1	14385	-499	26	1	1	0	0	56	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18549	8	6	3	0	3	7	1	14377	-500	26	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18609	8	6	3	0	3	7	1	14369	-500	26	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18669	8	6	3	0	3	7	1	14361	-499	26	1	1	0	0	57	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18729	8	6	3	0	3	7	1	14355	-499	26	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18789	8	6	3	0	3	7	1	14347	-499	26	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18849	8	6	3	0	3	7	1	14339	-499	26	1	1	0	0	58	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18909	8	6	3	0	3	7	1	14332	-500	26	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    18969	8	6	3	0	3	7	1	14324	-500	26	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19029	8	6	3	0	3	7	1	14318	-499	26	1	1	0	0	59	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19089	8	6	3	0	3	7	1	14310	-499	26	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19149	8	6	3	0	3	7	1	14303	-500	26	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19209	8	6	3	0	3	7	1	14296	-500	26	1	1	0	0	60	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19269	8	6	3	0	3	7	1	14288	-501	26	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19329	8	6	3	0	3	7	1	14283	-500	26	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19389	8	6	3	0	3	7	1	14275	-499	26	1	1	0	0	61	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19449	8	6	3	0	3	7	1	14268	-499	26	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19509	8	6	3	0	3	7	1	14261	-499	26	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19569	8	6	3	0	3	7	1	14254	-498	26	1	1	0	0	62	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19629	8	6	3	0	3	7	1	14247	-499	26	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19689	8	6	3	0	3	7	1	14240	-500	26	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19749	8	6	3	0	3	7	1	14233	-500	26	1	1	0	0	63	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19809	8	6	3	0	3	7	1	14227	-499	26	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19869	8	6	3	0	3	7	1	14219	-500	26	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19929	8	6	3	0	3	7	1	14212	-499	26	1	1	0	0	64	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    19989	8	6	3	0	3	7	1	14205	-499	26	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20049	8	6	3	0	3	7	1	14198	-500	26	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20109	8	6	3	0	3	7	1	14192	-499	26	1	1	0	0	65	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20169	8	6	3	0	3	7	1	14184	-501	26	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20229	8	6	3	0	3	7	1	14177	-500	26	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20289	8	6	3	0	3	7	1	14170	-500	26	1	1	0	0	66	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20349	8	6	3	0	3	7	1	14162	-499	26	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20409	8	6	3	0	3	7	1	14156	-499	26	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20469	8	6	3	0	3	7	1	14148	-499	26	1	1	0	0	67	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20529	8	6	3	0	3	7	1	14140	-500	26	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20589	8	6	3	0	3	7	1	14132	-500	26	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20649	8	6	3	0	3	7	1	14125	-499	26	1	1	0	0	68	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20709	8	6	3	0	3	7	1	14118	-499	26	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20769	8	6	3	0	3	7	1	14110	-499	26	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20829	8	6	3	0	3	7	1	14102	-499	26	1	1	0	0	69	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20889	8	6	3	0	3	7	1	14094	-499	26	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    20949	8	6	3	0	3	7	1	14085	-499	26	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21009	8	6	3	0	3	7	1	14077	-499	26	1	1	0	0	70	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21069	8	6	3	0	3	7	1	14068	-499	26	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21129	8	6	3	0	3	7	1	14060	-498	26	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21189	8	6	3	0	3	7	1	14051	-499	26	1	1	0	0	71	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21249	8	6	3	0	3	7	1	14041	-501	26	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21309	8	6	3	0	3	7	1	14032	-499	26	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21369	8	6	3	0	3	7	1	14021	-500	26	1	1	0	0	72	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21429	8	6	3	0	3	7	1	14012	-498	26	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21489	8	6	3	0	3	7	1	14001	-498	26	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21549	8	6	3	0	3	7	1	13991	-499	26	1	1	0	0	73	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21609	8	6	3	0	3	7	1	13979	-499	26	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21669	8	6	3	0	3	7	1	13967	-500	26	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21729	8	6	3	0	3	7	1	13957	-499	26	1	1	0	0	74	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21789	8	6	3	0	3	7	1	13944	-499	26	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21849	8	6	3	0	3	7	1	13930	-499	26	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21909	8	6	3	0	3	7	1	13919	-500	26	1	1	0	0	75	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    21969	8	6	3	0	3	7	1	13906	-499	26	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22029	8	6	3	0	3	7	1	13891	-499	26	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22089	8	6	3	0	3	7	1	13877	-500	26	1	1	0	0	76	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22149	8	6	3	0	3	7	1	13863	-499	26	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22209	8	6	3	0	3	7	1	13849	-500	26	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22269	8	6	3	0	3	7	1	13834	-499	26	1	1	0	0	77	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22329	8	6	3	0	3	7	1	13819	-498	26	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22389	8	6	3	0	3	7	1	13806	-500	26	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22449	8	6	3	0	3	7	1	13793	-499	26	1	1	0	0	78	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22509	8	6	3	0	3	7	1	13780	-499	26	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22569	8	6	3	0	3	7	1	13766	-499	26	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22629	8	6	3	0	3	7	1	13754	-499	26	1	1	0	0	79	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22689	8	6	3	0	3	7	1	13743	-498	26	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22749	8	6	3	0	3	7	1	13730	-500	26	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22809	8	6	3	0	3	7	1	13718	-499	26	1	1	0	0	80	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22869	8	6	3	0	3	7	1	13707	-498	26	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22929	8	6	3	0	3	7	1	13693	-500	26	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    22989	8	6	3	0	3	7	1	13681	-498	26	1	1	0	0	81	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23049	8	6	3	0	3	7	1	13669	-499	26	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23109	8	6	3	0	3	7	1	13655	-500	26	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23169	8	6	3	0	3	7	1	13640	-499	26	1	1	0	0	82	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23229	8	6	3	0	3	7	1	13627	-500	26	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23289	8	6	3	0	3	7	1	13612	-498	26	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23349	8	6	3	0	3	7	1	13598	-499	26	1	1	0	0	83	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23409	8	6	3	0	3	7	1	13582	-499	26	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23469	8	6	3	0	3	7	1	13565	-500	26	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23529	8	6	3	0	3	7	1	13548	-500	26	1	1	0	0	84	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23589	8	6	3	0	3	7	1	13531	-499	26	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23649	8	6	3	0	3	7	1	13512	-499	26	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23709	8	6	3	0	3	7	1	13493	-499	26	1	1	0	0	85	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23769	8	6	3	0	3	7	1	13471	-500	26	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23829	8	6	3	0	3	7	1	13447	-500	26	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23889	8	6	3	0	3	7	1	13421	-499	26	1	1	0	0	86	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    23952	8	6	3	0	3	7	1	13388	-500	26	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24012	8	6	3	0	3	7	1	13353	-499	26	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24072	8	6	3	0	3	7	1	13314	-499	26	1	1	0	0	87	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24132	8	6	3	0	3	7	1	13272	-498	26	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24192	8	6	3	0	3	7	1	13223	-500	26	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24255	8	6	3	0	3	7	1	13166	-500	26	1	1	0	0	88	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24315	8	6	3	0	3	7	1	13105	-499	26	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24375	8	6	3	0	3	7	1	13038	-500	26	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24435	8	6	3	0	3	7	1	12967	-499	27	1	1	0	0	89	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24495	8	6	3	0	3	7	1	12890	-499	27	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24555	8	6	3	0	3	7	1	12807	-500	27	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24615	8	6	3	0	3	7	1	12718	-499	27	1	1	0	0	90	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24675	8	6	3	0	3	7	1	12622	-499	27	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24735	8	6	3	0	3	7	1	12516	-498	27	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24795	8	6	3	0	3	7	1	12401	-500	27	1	1	0	0	91	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24855	8	6	3	0	3	7	1	12271	-500	27	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24915	8	6	3	0	3	7	1	12124	-500	27	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    24975	8	6	3	0	3	7	1	11947	-499	27	1	1	0	0	92	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25035	8	6	3	0	3	7	1	11746	-499	27	1	1	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	65535	-1	65535	65535
    25083	9	10	4	0	0	17	0	0	0	27	0	0	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
    25083	9	0	4	0	0	16	0	0	0	27	0	0	0	0	93	65535	65535	65535	65535	0	0	0	0	0	0	0	0	0	0	0	0	65535	65535	0	0	0	0
  • this does not show any cell values. jus the pack overall
  • Hello Tony,
    Can you use TI tool chains to log the individual pack voltages?
  • I do still have one of these packs that I can discharge and recharge login the data.
    I will post that up tomorrow. (2020-10-27)
  • Thanks! This will help.
  • here is a log of a pack that has a large max-min cell voltage difference.
    ACPRS15_charge.log
  • Thank you this helps.
    I think the approach to resolving this one will be just to gather some data IVT log files using the bq20z655 and log over time to see what performance you can get.
    There's no magic equation we really have.
  • let me bottom line this for you.
    New cells work perfectly with the learn cycle (charge, place in learn, discharge, wait, charge, wait, discharge, wait)
    cells that we bought a year ago and sat waiting on a shelf do not do so well. the reported capacity is much lower and the cell to cell balance is really not great as reflected in the log file in this thread.
    The question I have is about the operation of your BQ charging and balancing IC.
    For the packs made with the new cells, are we going to see that kind of poor performance down the road?
    Is there a change of some kind that we can do to mitigate that performance loss?
    this should be answerable with the data that is currently available. more testing and logging will not answer that question.
  • Hi Tony,
    We can't guarantee any kind of performance, we are more than happy to help if you run into more issue.
  • What more information can I provide?  you have a log of a charge cycle. you have the IC config that we are using. you have the PN of the batteries we are using in the pack.
    We would be happy to provide more data, let us know what data you need.
    Tony Brenke
  • Hi Tony,
    Let us look into your questions and get back to you next week.
  • Hello Tony,
    If you are having issues with the cell balancing with older cells this would be expected, as cells age the age at different rates and would have different internal resistances.
    You may need a larger external balancing network to keep the cell voltage from deviating over time.
    Also if you are using older cells you may need to perform a learning cycle on them separate from the new cells because they have different characteristics.
    Sincerely,
    Wyatt Keller
  • Wyatt,  thank you for your responce. The pack in question was all older cells. A learn cycle was done. Then a few charge and discharge cycles were done to see if the initial balancing after the learn cycle improved. It did not.
    The end goal with this Ic was to do a learn cycle, charge the pack up to shipping voltage level then ship them to the end user. These packs would be sealed at that point in time so an external ballancing network would not be a posablity.
    There does not seam to be an aceptable answer to this.  In this configuration it looks like we will have a usable life of 2 years and that is it.
  • Hello Tony,
    The gauge may not be able to cell balance quickly enough for your application since it uses passive cell balancing.
    The resistances are described in the TRM for how long it may take to balance the cells.
    Sincerely,
    Wyatt Keller
