Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS62361B: Default startup
Part Number: TPS62361B
Hello team,
I have a question for TPS62361B default startup.
Before I2C communication, what is the default output voltage and ramp up speed as a default setting?
(Or, Is there any way to determine the default value?)
Thanks in advance.
S.Sawamoto
  • Hello Sawamoto-san,
    The default values for the four output voltage presets are documented in Table 2 of the datasheet:
    The default values for the ramp up speed register are documented in Table 10 of the datasheet:
    RMP[2:0]=000 meaning that the default ramp speed is 32mV/us according to Table 5:
    Thanks!
    Yann Ducommun
