How to control the LED brightness separably for each LED.
Which registers to set to assign a PWM signal to each LED ?
Hi, guy,
Reference to page 5 of the datasheet(which is attached following), the LP5012 is designed with dependent color mixing and intensity control. you can control the LED brightness separably for each LED by the color-mixing.
The PWM signal is determined by color-mixing and intensity control, but you can set up the color-mixing register to control each LED, which you can refer to the following pic.
Best regard
Monet Xu
