Dear Sir or Madam,
I would like to use the REG71050 to supply an LED matrix in a battery powered application.
The measured repeating current peaks exceed the 60mA given in your data sheet.
Could you please check the attached waveform(100mV = 1mA) or give me a value for the maximum repetitive output current the mosfet switches can handle?
Thanks for your response.
Dominik Schmid
