I am designing my converter around the LM5155. I would normally expect to see a specification regarding the FB pin input bias current, but I have not found this in the datasheet. This current level may determine my maximum resistor values for the FB divider. With 80V maximum output and limited space and input power available, I do not want to burn too much power in my FB divider. Is there any guidance regarding limits on the FB pin input current, or at least a maximum recommended value for the lower divider resistor?
Thanks.
