I would like to ask you about the LMG3411R050 device.
Does this device have a Spice model in the library in the PSpice for TI simulation environment?
Hello Kaji,
We do have LMG3410 SPICE model, which can be found in the following link: https://www.ti.com/product/LMG3410R050#design-development
The only difference between the LMG3410 and LMG3411 is the over current protection method: latched vs. cycle by cycle.
Also if you use PSpice for TI, their should be model existed in the built-in library.
Hope this helps.
Thank you for your reply.
Is the LMG3410 SPICE model present in the PSpice for TI embedded library?
Yes, that's correct.
If it helps, could you click the "this solves my issue" button?
Thanks!
