LM5141QRGEVM: Soft start problems
Part Number: LM5141QRGEVM
Hi team,
I'd like to figure out the soft start working pattern, and I'm using the evaluation module.
-Is there any other element effect on the soft start time or behavior except the soft start capacitor Css? How?
-According to the datasheet, soft start shows different result due to low-side MOS between FPWM and DEMB mode. So is there gonna be different if I change the resisters at HO/LO?
-When SS pin turns low voltage, is it because of load changing and current excess the limit? Does it needs soft start again?
Many thanks
Frank
