Hi team,
Could you give me comment on following customer questions?
Q1. How to detect enabling/disabling the watchdog timer through WDI pin?
Q2. When disabling the watchdog timer with floating WDI pin, will reset trigger accidentally happen by adding noise on the floating WDI pin?
Q3. Can WDI pin be pulled low or pulled high in order to disable the watchdog timer instead of floating WDI pin?
Takeshi Sasaki
