Other Parts Discussed in Thread: UCD9090A,
We are using TPS54620RGYT for generating Negative voltage supply but we encountered that we are not able to control the Converter with the Enable pin .
For Enable signal we are using UCD9090A which is able to control other Power Converters , please find below the Image and Design and provide comments :
As you can observe output is enabled even after the enable is Toggling .
